 Post subject: Magnified/Zoomed systrayicons out of screen
PostPosted: Mon Mar 29, 2010 4:02 pm
I noticed that, with the latest build, when my systraydock is at the top of the screen, the icons when magnified/zoomed appear abit outside screen view.
Maybe its possible to keep them inside?
Another question:
Is it possible for the systray icons, when not grouped, to be small too?
 Post subject: Re: Magnified/Zoomed systrayicons out of screen
PostPosted: Mon Mar 29, 2010 4:35 pm
Heh? Did you enable the 'Do not flip backgrounds for docks at the top of the screen setting'? Otherwise docks at the top of the screen magnify down, not up.
raraz wrote:
Another question:
Nope, sorry. All icons in a dock must have the same size.
PostPosted: Mon Mar 29, 2010 5:26 pm
That option is unchecked.
Ah...with magnify they indeed magnify inside.
However with zoom and bounce they go outside.
Funny thing is that when I check that flip option you talked about, then the bar ends up 2 centimeter below the top screen edge. (The 3 options below that flip option are unchecked)
PostPosted: Mon Mar 29, 2010 6:33 pm
Ah, yes, I see what you mean now. I don't remember ever trying the bounce effect with the maximum magnitude (Effects tab in Preferences -> Effect Settings button -> Magnitude) - it's really cool to see the icons bounce like that, and the motion is very fluid. Unfortunately they do bounce off the screen edge.
One thing you can do for now is offset the dock from the screen edge a bit (Position & Behavior tab).
Ahah! Only when the magnify effect is enabled - otherwise you would get precisely what you are complaining above: the icons magnifying off the top edge of the screen.
Users browsing this forum: Google [Bot] and 35 guests
