 Post subject: Nexus 10.3 Running App Indicator
PostPosted: Mon Mar 29, 2010 3:51 pm
After just updating to Nexus 10.3 I noticed that suddenly the indicator that's supposed to show what apps in the dock that's currently running is not working anymore.
I've tried using different themes and different indicators and having the offset set from anything from Nothing to All on the slider, but still no go.
Have also tried restarting both computer and Nexus several times but the problem still remains.
Hope you can fix this ^^
Time flies like the wind
Fruit flies like bananas
 Profile YIMICQ
PostPosted: Mon Mar 29, 2010 4:40 pm
Gah. Fix one thing, break another.
You can get them back by inserting a CPU meter module on the dock. Will be fixed in the next release, sorry.
PostPosted: Mon Mar 29, 2010 4:53 pm
You can delete the CPU meter from the dock afterwards if you first right click on it and select 'Show Tray Icon'.
PostPosted: Mon Mar 29, 2010 7:40 pm
Done as you wrote so it works for now ^^
Just don't fix it in next release by adding another bug in it's place ;)
 Profile YIMICQ
Users browsing this forum: Apple [Bot], Majestic-12 [Bot] and 28 guests
