 Post subject: Seperator(s) between Tasklist and Systemtray icons
PostPosted: Sun Mar 28, 2010 9:42 am
Right now when I want to put a seperator between the tasklist and the systray, it just wont let me.
When I put a seperator somewhere left from the tasklist, it appears between tasklist and systray too.
As it is now it looks a bit buggy imo.
Hope it can be fixed.
Also, is it possible to see the icon context by right clicking a systray icon? Right now it shows the Nexus context text.
PostPosted: Sun Mar 28, 2010 11:30 am
The update had it's share of problems, which I'm fixing now.
The label for groupped tray icons works if you're using the magnify effect, but not if you're using some other effect.
I assume you have the tray icons groupped and are using a dock mouse over effect other than magnify and flat magnify, right?
As for the tray separator, that part is buggy too: the separator should always be there when using groupped tray icons _OR_ when the systray is not groupped but set to show all icons (in the latter case the systry expand button serves as a separator).
Something else you should realize is that you cannot add items to the right of the task or tray areas.
PostPosted: Sun Mar 28, 2010 3:06 pm
Ah....indeed. With magnify the context works alright.
PostPosted: Mon Mar 29, 2010 7:57 am
There's a new update out (10.3.887) that should fix all the problems you mentioned. :D
PostPosted: Mon Mar 29, 2010 7:59 am
Errr, are you running Nexus or Winstep Xtreme? Or did you install both?!
Users browsing this forum: No registered users and 53 guests
