 Post subject: NextStart - newbie question - using 10.3 beta
PostPosted: Sat Mar 27, 2010 9:08 am
I've noticed that the proper program icons are missing from the replacement start menu and task bar. System icons are there.
For example, the internet and email icons are represented by a white page icon at the top of the start menu. If there is more than on instance of Firefox open, the task bar loses the orange icon and the group shows the plain white page icon as shown in the start menu.
Any ideas?
Running Win 7 64-bit. Icon packager is installed.
PostPosted: Sat Mar 27, 2010 10:07 am
That's an IconPackager bug. You're seeing something like this, right?
IP Blank Icon Fix here
 Post subject: Fixed!
PostPosted: Sat Mar 27, 2010 11:31 am
Yes exactly the problem. Ran the fix and everything is sweet. Thanks for your swift reply.
PostPosted: Sat Mar 27, 2010 1:54 pm
I'm on Win 7 x64 and it didn't work for me.
 Post subject: Re:
PostPosted: Wed Mar 16, 2011 3:26 am
For future reference, if the above fix doesn't work:
Go to 'Start' open run command, type in Regedit.
In the new window of Registry Editor go to HKEY_CLASSES_ROOT\exefile\shellex and delete the subkey/folder 'IconHandler'
http://forums.wincustomize.com/390822
Users browsing this forum: Apple [Bot] and 123 guests
