 Post subject: NextSTART Crash
PostPosted: Thu Mar 04, 2010 3:55 pm
I started using Winstep, yesterday. I noticed soon after using it that when I click the Start button of Winstep and then click on All Programs, Adobe Reader starts to launch right away for some reason. I have canceled Adobe reader but today I decided to let it run. When I did this NextSTART crashed. Here is the error report that I get.
Problem signature:
Problem Event Name: APPCRASH
Application Name: Nextstart.exe
Application Version: 10.1.0.537
Application Timestamp: 4b7385c0
Fault Module Name: OLEAUT32.dll
Fault Module Version: 6.0.6002.18005
Fault Module Timestamp: 49e037da
Exception Code: c0000005
Exception Offset: 00003e74
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1033
Additional Information 1: ca6a
Additional Information 2: 22ee85ff6c5e8f17ffbbdd86e8a744a8
Additional Information 3: e261
Additional Information 4: 14fec9d441023ba2fbdc54fda8f4423e
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
Any ideas of what I can do?
PostPosted: Thu Mar 04, 2010 5:17 pm
NextSTART needs to resolve shortcuts (.lnk files) in the All Programs menu.
Some shortcuts point not to the executables themselves, but to the Windows Installer.
For instance, a shortcut to Adobe Reader does not point to
C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe
but to
C:\Windows\Installer\{AC76BA86-7AD7-1033-7B44-A93000000001}\SC_Reader.ico.
In another example, the shortcut to Microsoft Word 2007 points to:
C:\WINDOWS\Installer\{91120000-0011-0000-0000-0000000FF1CE}\Wordicon.exe
instead of
C:\Program Files\Microsoft Office\Office12\WinWord.exe
These types of shortcuts need to be resolved first in order to get the proper filename. For some reason, the action of resolving the shortcut in your system also seems to cause the Windows Installer to launch Adobe Reader.
I'm looking into this, not sure if it is a problem with the method of resolving shortcuts or something specific to your system.
In the mean time, what Windows version are you running? What happens if you drag that shortcut from the NextSTART All Programs menu to, say, the dock? Does Adobe Reader also launch when you attempt to do this?
One thing you can do for now: right click on the NextSTART Start Button. Select 'Open All Users' from the context menu. Open the 'Programs' folder. Inside this folder you should find the shortcut to Adobe Reader - please move it to a temp directory so we can test any fixes later.
Now navigate to the Adobe Reader folder in C:\Program files\ (should be C:\Program Files\Adobe\Reader 9.0\Reader\) and create a shortcut to AcroRd32.exe in the 'Programs' folder by right-click and dragging the executable file. This should put a stop to Adobe Reader launching when you open the All Programs menu in NextSTART (although it does not fix the actual cause).
PostPosted: Fri Mar 05, 2010 3:01 pm
Before I was able to do any of your suggestions, I rebooted my pc and everything seems to work fine now. I did notice that there is an Adobe Reader 8 shortcut on my desktop now with Target "C:\Program Files\Adobe\Reader 8.0\Reader\AcroRd32.exe". I guess that is what it was trying to do when I hit the "All Programs" tab. When I click on "All Programs" now it does what its supposed to without crashing.
Thanks for your quick response.
Users browsing this forum: Apple [Bot], Majestic-12 [Bot] and 23 guests
