 Post subject: nexus 10.1
PostPosted: Thu Feb 18, 2010 4:58 am
I've been using Nexus for a good while,when I updated to10.1 everything went south. Edge bump will not work. the regular desktop does not disappear either. I uninstalled the program and reinstalled it. Same problems.
what do I do to correct this
PostPosted: Thu Feb 18, 2010 8:18 pm
Few questions:
Are you sure you're running Nexus and not Winstep Xtreme? What do you mean by 'the regular desktop does not disappear'?
As for the edge bump, is your dock docked or floating on the screen?
PostPosted: Fri Feb 19, 2010 3:56 am
the dock is floating and I am running nexus. I have other programs like logon studio vista running.
PostPosted: Fri Feb 19, 2010 4:08 am
A floating dock will not respond to an edge bump, *unless* you have selected that option as an activation method in the Position & Behavior tab in Preferences. Have you?
You also still didn't explain what you mean by 'Regular desktop does not disappear'. Are you talking about hidding destkop icons automatically on startup?
PostPosted: Sat Feb 20, 2010 3:04 am
I have the bottom edge bump working.The Vista desktop used to disappear when running Nexus. It would be a solid blue with no icons. Programs would then run from the dock. I am not running the extreme program, Just Nexus free..
PostPosted: Sat Feb 20, 2010 3:26 am
Winstep Xtreme has the option to hide desktop icons at startup. Nexus does not, but, if I remember correctly, it does have an internal command that does the same thing.
 Post subject: Nexus 10
PostPosted: Sat Feb 20, 2010 4:50 am
Got the vista desktop to disappear using Internal commands. Thank you for your time and advice.
Users browsing this forum: Apple [Bot] and 21 guests
