 Post subject: Winstep Xtreme 10.1 Public Beta 1 Released!
PostPosted: Thu Feb 11, 2010 2:31 am
The 10.1 beta 1 release is a major milestone in the development of Winstep Xtreme: the whole suite now features full multi-language support as well as a modern, clean, and super-intuitive User Interface:
1 - Download the 10.1 beta from
http://www.winstep.net/xtreme-beta-full.zip
2 - Exit all Winstep applications.
3 - Run XtremeSetup.exe
Winstep Xtreme currently features a mix of complete and incomplete language files, in particular for the NextSTART component. If you would like to help translating Xtreme into your language, please read THIS topic first and then contact Winstep support.
New Features (in relation to Winstep Xtreme 9.5):
* Completely redesigned User Interface.
* Multi-language support.
* Full Windows 64 bit support.
* Full Windows 7 support.
* Brings Nexus functionality and features up to par with the free Nexus version.
* Fixed incompatibilities between NextSTART's systray and Skype 4.x
* Fixed incompatibility with Logitech's Setpoint under 64 bit systems that caused menus, docks and the shelf to become blank and unresponsive.
* Fixed a problem where Winstep applications grabbed the focus from the desktop under Win7, making it difficult to select and rename desktop icons.
* Real Time theme previews.
* New Hotspots Wizard.
* New Menu Editor.
* Classic and Windows 7 style taskbar.
* Nexus native and 3rd party dock themes are now displayed together and handled the same way.
* Much improved system tray management (system tray size and orientation no longer dependent on the original Windows system tray, etc...).
* In-dock and in-shelf modules can now be renamed.
* User definable folder for storing screenshots taken by the Capture Desktop internal command.
* Dock backgrounds can optionally NOT be flipped when the dock is at the top half of the screen.
* Browse and Browse Container menus now support drag & drop.
* Countless other features and fixes!
A complete list of additions, changes and fixes (and there are many) can be found by reading the history files in the C:\Program Files\Winstep folder after installation.
Enjoy,
Users browsing this forum: Apple [Bot], nexter and 30 guests
