 Post subject: Windows Key...
PostPosted: Tue Apr 13, 2004 5:53 pm
Is there some way to have the Windows Key open the NextSTART menu and not my Windows Start menu?
Sorry if I've missed it somewhere.
Brian Howe
Platinum Computing Systems
PostPosted: Tue Apr 13, 2004 7:40 pm
From the NextSTART FAQ (Frequently Asked Questions):
Q) Can I use the WIN or CTRL-ESC keys to pop up my NextSTART menu instead of the normal Windows Start Menu?
A) No, and this is by design. We feel that the Windows Start Menu should always be available in case a user deletes his NextSTART menu by accident or something bad like that... Besides, you can always use other hotkey combinations (CTRL-? or ALT-? key combinations) to invoke the hotspot associated to the main NextSTART menu - it's just a question of getting used to a new keyboard shortcut. NextSTART Corporate does allow you to disable the WIN and CTRL-ESC keys, but the intention here is to provide a secure desktop.
Users browsing this forum: Apple [Bot] and 19 guests
