 Post subject: workshelf help!
PostPosted: Sat Jan 09, 2010 4:49 am
I've downloaded the winstep extreme but can't seem to find the workshelf.exe anywhere .
Help??
PostPosted: Sat Jan 09, 2010 8:52 am
Exactly where did you download Winstep Xtreme from?
PostPosted: Sun Jan 10, 2010 2:25 am
from the winstep site
PostPosted: Sun Jan 10, 2010 10:13 am
Yes, but what URL (link) did you use?
Trying to establish if you indeed downloaded Winstep Xtreme rather than, say, Nexus.
PostPosted: Sun Jan 10, 2010 10:19 am
http://www.winstep.net/index.asp?cat=winstep
PostPosted: Sun Jan 10, 2010 11:12 am
If you go to C:\Program Files\Winstep (or C:\Program Files (x86)\Winstep if you are running a 64 bit version of Windows), don't you see a file called WorkShelf.exe? What happens when you run it?
I'm not sure what your expectations are, but if you see a dock on your screen and some desktop modules/widgets (like the clock and weather monitor) then WorkShelf.exe is already running on your system.
PostPosted: Sun Jan 10, 2010 12:36 pm
nope .. no workshelf.exe and i don't even have the modules. ( maybe i miss sth while installing ,i'm not sure)
These are all the exe. files in my winstep folder
Fontbrowser.exe
Nextstart.exe
Nexus.exe
winstepxtreme.exe
wskeymanager.exe
wsorganizer.exe
wsrollback.exe
Wstranslator.exe
wsupdate.exe
wsxservice.exe
PostPosted: Sun Jan 10, 2010 1:09 pm
I'm not sure what you did in there, but somehow you managed to mix an installation of the stand-alone Nexus version with Winstep Xtreme. Rather weird... :roll:
From the URL you gave me, did you download 9.5 or the 9.12 beta? Also, did you install any updates after?
Anyway, I suggest you manually delete Nexus.exe and then download the Xtreme 9.12 public beta from HERE and re-install on top (i.e.; do NOT uninstall anything before).
Please let me know how it went... :D
PostPosted: Sun Jan 10, 2010 1:26 pm
It works! ... kinda different from the one i downloaded =S
Thank you so much!! =D
Users browsing this forum: Apple [Bot] and 21 guests
