 Post subject: System tray bug
PostPosted: Tue Dec 29, 2009 3:51 pm
My clock used to disappear occasionally. Now, it is the entire System Tray which disappears. This has occurred among other instances when I close out a game. Anyone else seeing this?
PostPosted: Thu Dec 31, 2009 4:08 am
As you know by now, I'm currently working on NextSTART's new UI (which means I'm focusing on NextSTART, hehe). I'll have a look at the kind of glitches you describe as soon as the UI is finished.
Could be because the systray gets repositioned when the Game changes screen resolution. Or it could be a z-order problem (do you have your NextSTART taskbar set to Always on Top?).
PostPosted: Thu Dec 31, 2009 2:58 pm
It is set to always on top. I'm pretty sure it has happened other than when exiting a game. I will pay more attention next time it occurs!
BTW, I never understood what Z-order was all about?
Looking forward to new GUI. No distractions like disappearing trays & clocks!!! (he, he).
PostPosted: Thu Dec 31, 2009 3:04 pm
I believe I can guess what he means with the z-order.
You got the axis system, the X axis (left to right) Y axis (bottom to top) and the Z axis (which is basically depth, and isn't a real axis on your screen, but an imaginary one). So I guess the Z-order means which window is on top of which window.
PostPosted: Thu Dec 31, 2009 5:31 pm
kutagh:
Sounds reasonable. We will see!
Users browsing this forum: Apple [Bot], Bing [Bot], nexter and 30 guests
