 Post subject: Nextstart: QuickLaunch-Folder Menu item size change?
PostPosted: Mon May 03, 2010 2:33 pm
I thought this option might be available, but I cannot seem to find it if it is. See below link for screenshot.
I have added a Hotspot-Folder Menu to my quick launch to give me quick access to a lot of items from a menu list. The list (with my resolution) is quite small to read. Is there a way to specify an icon/item size for just this menu?
http://dl.dropbox.com/u/3840697/Capture.PNG
Thanks in advance.
kwickone I.T.H.
PostPosted: Mon May 03, 2010 3:10 pm
Sorry, not really, at least not without directly modifying the theme.
The problem is that the bitmaps of some themes do NOT support an automatic icon size change and would look really bad when used with an icon size that not the one intended by the author.
This said, there is a work-around, but it would involve making a copy of that theme, give it a different name, modifying the new theme, and then attaching the new theme to that particular Quick Launch hotspot. Not really recommended at this point, at least not until the new Winstep Skin Manager/Builder is available.
PostPosted: Mon May 03, 2010 3:15 pm
Thanks for the quick reply Jorge. And no worries...not a huge deal at this point, just a nice to have.
And thanks for being such an active and responsive developer! In a world of "one hit wonders" who start an app, make money, and never update it, you stand out of the crowd!!!
:D :D :D
kwickone I.T.H.
PostPosted: Mon May 03, 2010 4:14 pm
:D :D :D
Exactly right!!! Jorge is the most responsive, thoughtful and cordial developer I've ever come across.
Users browsing this forum: Apple [Bot], Google [Bot] and 89 guests
