Board index : Winstep Forums : General Discussion  [ 25 posts ] Go to page 1, 2  Next
 Post subject: 9.5 Misbehaving?
PostPosted: Wed Nov 25, 2009 9:46 pm
On my Sony HD Touchscreen VPCL117FX/B W7 Home Premium My Nexus and Workshelf WS) are not orienting as they should. The screen res 1920x1080p... If I try to get it on the bottom it goes to midscreen and stops. It can dock to the top.
Intel® Core™ 2 Quad Q8400S processor (2.66GHz1) with 6GB of pre-installed system memory. 1TB (7200rpm) hard disk drive. NVIDIA® GeForce® GT 240M GPU and 1GB of dedicated video RAM.
Nexus is on the right but up towards the top of the screen despite being set at center (docked).
Any ideas?
Dr.J.
PostPosted: Wed Nov 25, 2009 9:50 pm
Open NextSTART Preferences, Global Preferences tab. In the Reserve Screen Space section, is any of the four values anything other than zero?
PostPosted: Wed Nov 25, 2009 10:24 pm
No. All are zero.
Another thing: All my browsers will not open to full screen when Winstep is running, but when I exit Winstep, they can assume normal behavior of maximizing.
Dr.J.
PostPosted: Thu Nov 26, 2009 8:38 am
I have seem this exactly *once* before. Apparently *something* is causing Winstep Xtreme to reserve more screen space than it should.
My guess is that it has something to do with screen DPI.
PostPosted: Thu Nov 26, 2009 12:39 pm
Does that mean "no solution"?
Dr.J.
PostPosted: Thu Nov 26, 2009 12:54 pm
Means I will be looking into this... :wink:
PostPosted: Thu Nov 26, 2009 1:36 pm
Thanks, Jorge...I appreciate the help, really.
Dr.J.
PostPosted: Fri Dec 04, 2009 3:43 am
Don't mean to bother, but any progress towards a solution?
Dr.J.
PostPosted: Fri Dec 04, 2009 4:05 am
Not really, sorry, been busy with the NextSTART new UI (making great progress on it, by the way - not that it is any consolation to you).
I do have one question, though: did you change the default screen DPI in any way (i.e.; enabled large fonts or something like that)?
PostPosted: Fri Dec 04, 2009 12:58 pm
No...just installed it. Made no changes in the sizes of icons or fonts.
Good news about the progress with the new UI, though!
Dr.J.
PostPosted: Fri Dec 11, 2009 2:01 am
Any progress?
Dr.J.
PostPosted: Fri Dec 11, 2009 2:21 am
Doc, don't worry, it's not forgotten, but even if I manage to fix it I won't be able to issue an update (private or otherwise) until I finish the new NextSTART UI, sorry... :cry:
The only thing you can do for now is disable all the Reserve Screen Space/Prevent Maximized Windows from Overlapping... options.
PostPosted: Fri Dec 11, 2009 12:10 pm
That's ok....no pressure. I know you're doing all this by yourself. I admire you for that, Jorge. Truly.
When it happens, it happens. It'll be ok. ;)
doc
Dr.J.
PostPosted: Sat Mar 20, 2010 5:53 pm
Just to remind you I'm still waiting....
Dr.J.
PostPosted: Sat Mar 20, 2010 6:15 pm
Have you tried installing the latest private beta release available in the Beta Discussion forum? I've fixed an issue that *might* be related to this.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 25 posts ] Go to page 1, 2  Next
Users browsing this forum: Apple [Bot], Google [Bot] and 125 guests
