 Post subject: Start menu organiser?
PostPosted: Mon Nov 16, 2009 6:18 am
I have a pretty good handle on how the organizer works but had a question. You have three windows on the organizer "Catagories", "Items in (name of category) Category" and "Uncategorized Start menu items".
So the "Uncategorized Start menu items" is a list of all installed items on your PC correct? So after I get all the items listed the way I want in the "Catagories" list, do I then delete what is left over in the "Uncategorized Start menu items" list if I don't want them listed in the actual start menu?
Am I thinking about this correctly? I notice that even after getting everything set up the way I want in the "Catagories" list, anything left in the "Uncategorized Start menu items" list still shows up in the start menu.
I'm including a screen shot.
PostPosted: Mon Nov 16, 2009 6:32 am
...do I then delete what is left over in the "Uncategorized Start menu items" list if I don't want them listed in the actual start menu?
Yes, that is the way it should be. To delete the items left in the Uncategorized Start Menu Items panel, if you really don't want them on your Start Menu, just right-click and select 'Delete'.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 111 guests
