 Post subject: Adding Nextstart preferances button to shelf?
PostPosted: Wed Nov 11, 2009 4:51 pm
I'm still setting up Winstep Extreme and all is going well. On one of my shelf's, I have a button to the Workshelf preferences. It was already there after install. I would like to add a button on the same shelf for Nextstart preferences. My goal is to eliminate the little task bar icons down by the clock, which is how I currently get to the preference screens.
Any way to do this?
Thanks!
PostPosted: Wed Nov 11, 2009 6:05 pm
You can press CTRL+F10 to access NextSTART Preferences and CTRL+F11 for WorkShelf Preferences.
Also, double clicking the titlebar of a NextSTART menu opens NextSTART Preferences (and you can right click on an empty place of the NextSTART taskbar and access Preferences from the context menu).
Lots of ways to skin a cat. :D
PostPosted: Wed Nov 11, 2009 10:26 pm
Ha! Those work for me!! :D
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 120 guests
