 Post subject: Do YOu Need To BACK UP YOUR PC ?
PostPosted: Wed Sep 30, 2009 10:10 pm
hello please help...
Do i need to back up my windows pc system before using winstep extreme 9.5 ?
Or is its not like windows blind software,
where you have to back it up before using it?
Does winstep chang anything on your PC system. Or Is It just that The software that change? (when its running)..
And when you close winstep extreme 9.5 every thing on you pc goes back to normal?
:lol: :shock: :D :P PLEASE HELP AS SOON AS YOU CAN :lol: :) :D
 Post subject: Re: Do YOu Need To BACK UP YOUR PC ?
PostPosted: Wed Sep 30, 2009 11:47 pm
Not at all.
jonedoe wrote:
Or is its not like windows blind software, where you have to back it up before using it?
No. In fact, Winstep Xtreme is nothing like WindowBlinds in that it only skins itself, it does NOT skin the windows of other programs.
That's right, nothing is changed on your system, and getting back to 'normal' Windows is a simple question of exiting Winstep Xtreme.
Give it a try, it's perfectly safe to install. :D
 Post subject: thanks .. i love winstep etreme soooo much
PostPosted: Thu Oct 01, 2009 12:21 am
thanks for the answers.
that realy helped.
i have been using winstep extreme for about 3 years now. And i never knew that...
i love this software better then (windows blind) for me at least..
:lol: :lol:
pss. you just made me FEEL ALOT better about this software :roll:
the fact that it does not change anything on your system and that you don't need to back your system up is sooooo AWsome....
i have it on all the laptops and pc's i have ...
it look's soooo cool .. :lol:
Users browsing this forum: Amazon [Bot], Apple [Bot] and 60 guests
