 Post subject: Cannot launch programs in taskbar
PostPosted: Thu Sep 03, 2009 3:48 am
I'm not sure why, I may have accidentally clicked on something, but I cannot launch running programs sitting in the tasklist. If I disable the tasklist in the NextStart Tasklist and Systray Preferences, and go back to the regular Windows task bar, I can launch everything. I could do this before, so I think I may have clicked on something to disable launching running programs from the task list. Any ideas? :?:
PostPosted: Fri Sep 04, 2009 5:18 am
Please help im having the same problem using the aero theme...
PostPosted: Fri Sep 04, 2009 9:48 am
Open NextSTART Preferences -> Global Preferences tab -> Mouse Settings.
What are the settings for Tasklist Actions? If they are all set to 'None', that's the problem.
Users browsing this forum: Amazon [Bot], Apple [Bot], GPT [Bot] and 31 guests
