 Post subject: I've hidden workshelf and nexus.. how do I get them back?
PostPosted: Tue Aug 11, 2009 5:45 pm
Ok I messed up. I turned off workshelf and nexus and I do not have the workshelf try icon visible and now I have no way to bring up the workshelf configuration screen. How can I get access to the configuration screen or what registry value can I change to make tthe dock or shelf visible.
 Profile ICQ
PostPosted: Tue Aug 11, 2009 6:59 pm
Ctrl F11 is the default hotkey to bring up the preferences dialog (unless you have changed this). You will be able to reset everything from there.
PostPosted: Tue Aug 11, 2009 11:32 pm
That worked, thanks!!!
 Profile ICQ
PostPosted: Thu Aug 13, 2009 7:20 am
No thanks needed, it was a pleasure.
Best regards
Users browsing this forum: Amazon [Bot], Apple [Bot] and 55 guests
