 Post subject: Change icons on the dock
PostPosted: Sun Aug 02, 2009 11:35 am
Hello,
I come to install the software Nexus dock, but I don't know how to make to change the icons which are on the dock.
thank you
PostPosted: Sun Aug 02, 2009 1:53 pm
Depends on the item type you want to change:
The Nexus control icon and module/widget icons are theme dependable, which means they cannot be changed directly. You can, however, change the style of the Nexus control icon (right click the control icon -> appearance and sounds -> Control Icon Color) or disable it completely.
All other items, just drop the icon (.ico,.png or .tif) image of your choice directly into the item, or right-click the item -> Properties -> Change Icon.
Users browsing this forum: Apple [Bot] and 23 guests
