 Post subject: Nexus - Transparent dock bg only (flicker)
PostPosted: Thu Jul 23, 2009 10:57 am
XP SP3 - Nexus 9.6B2
Have selected - "Apply transparency to dock background only (icons remain opaque)"
Dock Effects on Mouse over = Magnify
- When moving mouse pointer across the dock - the semi transparent dock background is drawn when the pointer is between icons - but when on top of a dock icon - it is magnified, and the dock background becomes fully transparent. When the mouse pointer moves off the icon and over another gap - the dock background is drawn again.
So the effect is the dock background flickers on and off as the mouse moves across.
Unselecting the option "Apply transparency to dock background only" the problem goes away.
Problem doesn't occur when the effect is anything other than "Magnify"
So combining "magnify" effect with "transparent dock background only" dock background becomes 100% transparent when icon is magnified.
I'm running standard xp ps/2 mouse drivers - no setpoint or intellipoint rubbish installed.
PostPosted: Thu Jul 23, 2009 4:23 pm
I have just tried the steps you list Bubby, and can confirm the same issue on my system Vista SP2 32bit Nexus 9.6B2
Best Regards
PostPosted: Fri Jul 24, 2009 4:22 am
What theme and % of transparency are you guys using?
PostPosted: Fri Jul 24, 2009 5:27 am
Nevermind, I think I fixed it already, thanks.
PostPosted: Fri Jul 24, 2009 11:10 am
It was AeroExec theme by webgizmo and any % transparency setting.
Best Regards
