 Post subject: Control Panel In Shelf
PostPosted: Mon Jul 20, 2009 12:30 am
When I add a Control Panel to my shelf this happens...
When I click on one of the icons ( ? ) nothing loads up.
Ive installed various builds of Win 7 and its always been the same.
Any ideas whats wrong?
PostPosted: Mon Jul 20, 2009 4:26 am
Is that the 32 bit or 64 bit version of Win7?
PostPosted: Mon Jul 20, 2009 10:33 am
64 bit
PostPosted: Tue Jul 21, 2009 2:54 am
Fixed for next release, thanks.
This said, Control Panel tabs and menus on 64 bit systems will not display all items. This is because of the forced Registry isolation between 32 bit applications and the 64 bit world.
The situation will remain like this until Winstep Xtreme becomes an hybrid 32 bit/64 bit application.
PostPosted: Tue Jul 21, 2009 9:51 am
When will that be? Before or after pigs fly and hell freezes over? ;)
PostPosted: Tue Jul 21, 2009 9:56 am
By the time you stop making wise cracks? :P :wink:
PostPosted: Tue Jul 21, 2009 1:15 pm
Good stuff, the support you give is awesome :)
Users browsing this forum: Apple [Bot] and 23 guests
