 Post subject: Problems Loading Themes
PostPosted: Mon Jun 22, 2009 9:24 pm
First off, I dunno if I should have used the same thread I started for a different question...
I have loaded many themes o.k. , they went nicely.Using the manual install method using Theme Management, most went in o.k., others appeared to have installed everything ...but not showing in the themes list.No errors at all.
PostPosted: Mon Jun 22, 2009 11:26 pm
Fred, you're going to have to start providing more details than this. :wink:
Exactly which themes did not install correctly? Where did you download them from (this question means you have to provide the URL for the themes in question so I can check them out and figure out what the problem might be). :D
PostPosted: Tue Jun 23, 2009 12:06 am
My apologies,see....starting out as such a noob :)
Makinarama
http://www.skinbase.org/rate.php?skins=10016
These 4 loaded, but DO NOT look nothing like the photos.
Work With A Vision For
http://www.skinbase.org/rate.php?skins=5013
Work On Fire For
http://www.skinbase.org/rate.php?skins=4886
Work While Bent For
http://www.skinbase.org/rate.php?skins=4773
Tandor
http://www.skinbase.org/rate.php?action ... skins=3238
PostPosted: Tue Jun 23, 2009 12:20 am
Those are Winstep Xtreme themes, and what you see there is the shelf (tabbed dock), menus (NextSTART), etc...
The freeware version of Nexus is only the dock component of Winstep Xtreme. To get the rest you will have to purchase Xtreme - the good news being that if you do it now, while I am still busy adding the new interface and multi-language support to all Winstep Xtreme components, you can do so for half price, or only $19.95 (regular price is $39.90).
Just click on the Xtreme URL in the About tab of Nexus Preferences to have access to this limited time promotion. :D
PostPosted: Tue Jun 23, 2009 3:10 am
Yup, I have the 30 day Extreme installed.As soon as I can I'll most definitely pay the small fee :D
Users browsing this forum: Google [Bot] and 35 guests
