 Post subject: NextSTART v3.4 Beta 6 and WorkShelf v1.90 Beta 5 Released!
PostPosted: Tue Oct 18, 2005 7:13 pm
Winstep Software Technologies releases NextSTART v3.4 Public Beta 6 and WorkShelf v1.90 Public Beta 5!
NextSTART Version 3.4 adds a multitude of enhancements such as Automatic Updates, Tip of the Day, improved drag & drop capability, new sound effects, the ability to capture WorkShelf modules as icons into the NextSTART Startbar, automatic refresh of the Startbar Quick Launch area, etc...
WorkShelf Version 1.90 allows you to view task icons as snapshots of the actual windows, task icon customization by simple drag & drop, new icon grow/shrink effect on mouse over, Preview button in the Advanced Skinning dialogs of desktop modules, redesigned Preferences windows, new Show Themes shelf type from where you can quickly visualize and apply themes, Browse In NextSTART context menu option for browsing folders using NextSTART menus, new Desktop Module effects, and much more!
You can download NextSTART beta 6 from
http://www.winstep.net/ns3-beta.zip
and WorkShelf beta 5 from
http://www.winstep.net/ws-beta.zip
Note: A previous full NextSTART, WorkShelf or Winstep Full Pak installation is required! Do not un-install anything, just install the betas on top of your current Winstep installation.
Please, do not forget that feedback is extremely important, specially for beta versions. Should you find a bug, please report it on the Winstep Forums or email support@winstep.net .
System Requirements:
WorkShelf and NextSTART will run under Win95/98/ME and NT4/2000/XP
PostPosted: Thu Oct 20, 2005 3:51 pm
What are the new sound effects?
PostPosted: Thu Oct 20, 2005 4:15 pm
Hmmm... Should have said 'Sound event' instead. It's the new NextSTART 'Select Item' sound event. You can now have a user selected sound when you mouse over items in NextSTART.
Users browsing this forum: Amazon [Bot], Apple [Bot], Majestic-12 [Bot] and 46 guests
