 Post subject: Idea...
PostPosted: Mon Oct 10, 2005 3:39 pm
I would like a small utility that would copy theme settings from one theme to all themes. One of the peevs I have is that some themes have mouse over menu expansion, others have a "click to expand menu" option. Is there already a way to synch settings between all themes?
PostPosted: Tue Oct 11, 2005 11:45 am
What you ask for is already there:
Open NextSTART Preferences and navigate to the Menu Preferences tab. Under 'Menu Behavior' you will see a 'Use Theme Auto Drop Down' option. Unselect it and automatic menu expansion can be controled by you (instead of the theme) using the option right under it.
PostPosted: Tue Oct 11, 2005 4:03 pm
:D
thanks!
Users browsing this forum: Amazon [Bot], winstep and 135 guests
