 Post subject: new window
PostPosted: Mon Oct 03, 2005 1:17 am
How can I enable a program to open in its own window and be expanded from the menu?
I have a few links that I visit frequently and have added them successfully on the menu, however, when I open a link it grabs the open window.
PostPosted: Mon Oct 03, 2005 5:26 pm
This behavior has nothing to do with NextSTART or WorkShelf. However, I believe you are talking about Internet Explorer, so:
1- Open the Tools sub-menu at the top.
2 - Click on 'Internet Options'
3 - Click on the 'Advanced' tab.
4 - In the Browsing section, unselect the 'Reuse windows for launching shortcuts' option.
5 - Click on the Ok button.
That should do the trick,
PostPosted: Tue Oct 04, 2005 3:54 pm
Geez ... should had that one.
Thanks for your time.
Users browsing this forum: Amazon [Bot], Apple [Bot], Majestic-12 [Bot] and 50 guests
