 Post subject: startup
PostPosted: Fri Sep 16, 2005 6:45 pm
Good morning, when I start the computer I have a few running programs including WinStep.
I only have Nextstep.
Why is the check mark for not showing the warning not sticking?
Why isnt the new menu I created not on the desktop? I have to use the ctrl-F12 to pull it up each time.
PostPosted: Sat Sep 17, 2005 5:17 am
Checkmark for Active Desktop warning not sticking? I'll have to check it up and I'll let you know if it is a bug.
Want to have a specific menu popping up every time you run NextSTART? Go to the Hotspot Preferences tab, select the hotspot associated to the menu (you did associate a hotspot to the menu, didn't you?) and make sure the 'Auto-Run' option is selected.
PostPosted: Sat Sep 17, 2005 5:06 pm
Thanks for your reply. Hotspot is working ....
Ive used the program Madonate to hide all icons and now removed the Active Desktop.
Looks good ... no flash of icons as well menu is in place. Thanks.
