 Post subject: Windchill
PostPosted: Sun Jan 25, 2009 1:46 pm
Currently enjoying Winstep XTreme 8.11. Got another suggestion for the weather module, following my comment last year which resulted in you fixing a bug related to sub-zero temperature display (C or F I can't recall which). The suggestion this time is similar: please display WINDCHILL data on the module. For those of you in tropical climes unfamiliar with windchill: it is an additional piece of weather data which estimates the effect of wind on how cold if FEELS to us. For example, the forecast might be for -10C temperatures, but high winds may result in it FEELING like -20C outside when windchill factor is included, which is a LOT colder. All the weather sites show the temperature including windchill, so I thought the weather module should also, to avoid always having to go to the website to check the temperature with windchill included.
Users browsing this forum: Google [Bot] and 72 guests
