 Post subject: 3 systray icons missing
PostPosted: Fri Jan 23, 2009 4:16 pm
Hey all,
Is anyone else seeing this symptom? I have had some offline conversations with Jorge, but we can't seem to nail this one down. I was hoping that a larger audience could weigh in.
In a nutshell, the 3 "system" icons in the systray (power, volume, and network) will disappear and not come back. I have used the hotkey Ctrl+F9, but does not work (ok, it will work maybe once in every 50 tries, but with no pattern of why).
See here for screenshot:
http://www.4shared.com/file/73246286/d5 ... ture1.html
You see that blank area to the right part of the systray....that is where they should be.
Some platform specifics:
Vista Business 32-bit, sp1
Dell Precision M90, 3.75GB RAM, 2.33GHZ Dual Core
Anyone else running Vista Business? Or using this model of Dell? Any other thoughts? This is driving me NUTS! Those are icons I NEED!
Thanks much!
kwickone I.T.H.
PostPosted: Fri Jan 23, 2009 11:58 pm
This seems to be a common problem in Vista... :cry: I'll try to nail it down for the next release.
In the mean time, next time you use CTRL+F9, try clicking on the NextSTART Startbar FIRST.
Users browsing this forum: Apple [Bot] and 56 guests
