 Post subject: Trying it out, but have a question about tasklist width
PostPosted: Fri Jan 02, 2009 2:03 pm
Just trying out the software and I really like it, but I want to see more of the tasklist and less of the quick launch sections. Is there a way to resize them horizontally? I'd like to see all of my running tasks, I don't like having to scroll to see them. I'd rather scroll through all my quick launch items.
PostPosted: Fri Jan 02, 2009 7:12 pm
Unfortunately you cannot limit the size of the Quick Launch area. Here are some ideas on what you can do, however:
1 - Resize the taskbar so it is two tasklist rows high.
2 - Right click on unnecessary Quick Launch items and select 'Remove from Quick Launch' from the context menu.
3 - Prevent the tasklist from showing your Quick Launch items (NextSTART Preferences -> Startbar Preferences -> Sections) and access them via a menu associated to a hotspot button or the shelf instead.
4 - Create a new empty dock, drag & drop all your Quick Launch items into it, and then disable the Quick Launch section from appearing on your taskbar.
Hope this helps somewhat. :D
Users browsing this forum: Amazon [Bot], Bing [Bot], Picco14 and 58 guests
