 Post subject: Skin clock button
PostPosted: Mon Dec 15, 2008 2:03 am
I can't for the life of me figure out which image skins the clock button in the systray. I would like to make it (The systray) smaller.....
***EDIT*** I guess it's not the clock button that prevents the startbar from getting smaller than ~32 pixels. It must be the systray. If i turn off the systray, i can size the startbar much smaller......Although turning off the systray seems to yield some odd button in the lower right corner when i have the startbar at the bottom of the screen.
PostPosted: Wed Dec 31, 2008 8:45 am
Try looking at the taskxxx images in your theme. They change both the task bar images as well as the clock button.
Users browsing this forum: Apple [Bot], Google [Bot] and 54 guests
