 Post subject: A couple questions
PostPosted: Thu Nov 13, 2008 11:20 pm
It looks like the "Reserve Screen Space" in NextStart only allows you to do so on the main monitor. Is there any way to say, reserve the space on one side of a specific monitor, instead of the main one? (I work on a 3-monitor system, and I'd like to reserve 32 pixels of space on the right side of the left monitor.)
I can't find any way to bring up the Workshelf other than a screen edge bump or a mouse over. Is there a way I could create a hotspot in NextStart and have it bring up the shelf when pressed?
Thanks,
-Eric Gooch
www.cybergooch.com
PostPosted: Fri Nov 14, 2008 1:17 am
For now all functions related to reserving screen space only work on the primary monitor, sorry. :cry:
I'll sort that out, but it might not be in time for the upcoming 8.11 release.
There is no way to uncollapse the shelf other than with a screen edge bump or a mouseover, *except* that you can assign a keyboard hot key to each tab in the Shelf (right click the Shelf's left mini-tab - or any other tab - and select 'Shelf Editor'). This hotkey will raise the Shelf if collapsed and automatically switch to the specified tab.
Users browsing this forum: Amazon [Bot], Apple [Bot], GPT [Bot] and 53 guests
