 Post subject: Installing Winstep on XP
PostPosted: Thu Nov 13, 2008 4:06 am
Hi Jorge, here's another one for you.
I've installed Winstep on my home PC (Vista). Works fine.
I also tried instlaling it on XP on my pc at work. However it did not appear to install any of the bundled themes at all. I tried several times, uninstalling and then reinstalling and had no luck.
I think had Winstep installed on that computer at one point quite some time ago, so perhaps some left over registry entry confused the install. Just a probably incorrect guess.
Chris
PostPosted: Thu Nov 13, 2008 4:23 am
Uninstall and make sure to delete any Winstep folder in c:\Program Files\
My guess is that the installer gets confused wether to use the old backward-compatible user data folder structure or the new Vista-compatible one.
Users browsing this forum: DuckDuckGo [Bot] and 87 guests
