 Post subject: Huge Systray
PostPosted: Thu Oct 02, 2008 6:11 pm
I was having a problem with a large startbar. After looking through the forums, i found that it had to be that something was forcing it to be a large start bar. Turns out it's my systray, the only way i've found to make the starbar smaller, is to detach the systray, but i feel like this solution is extremely temporary. Is there anyway to reduce the size of the systray?
%%Edit
I fixed it, it was due to the fact that my normal start bar was on the left side of the screen.
PostPosted: Thu Oct 02, 2008 7:57 pm
Glad to know you figured it out! :D
Users browsing this forum: winstep and 130 guests
