 Post subject: Nexus dock controller skinnable?
PostPosted: Tue Sep 16, 2008 8:14 pm
Hi, I'm testing xtreme and find the multiple docks idea great! But is there a way to change the NexUs icon on the different docks?
PostPosted: Tue Sep 16, 2008 10:13 pm
Yes, but you have to be aware that it is on a per-theme base.
For instance, suppose the current theme is Aero LowRes. What you do is to put a custom NxControl.png/icon image in the Aero LowRes theme folder (easiest way to open this folder: open the 'Themes' shelf, right click on 'Aero LowRes' and select 'Show Container').
Since each theme can have a different NeXuS control icon, you will have to repeat the above steps for each of the themes you are using.
Hope this helps,
PostPosted: Thu Sep 18, 2008 7:52 pm
Thanks for the quick reply. Well, that's fine for a start. I hope a next version could allow to customize the NeXus icon to anything else though. I would like to have all my graphics apps on a dock collapsable to a more representative icon, and so on with all other apps.
PostPosted: Thu Sep 18, 2008 9:41 pm
Ah, I see where you are getting at. :D
Still, you are aware that NeXuS supports sub-docks, no?
PostPosted: Fri Sep 19, 2008 12:25 am
Yep. Well, I'm still testing - not in full mode.
Anyway, I want to completely walk away from trees and hierarchical folder systems and have like different areas scattered throughout the desktop, graphically identifiable, containing groups of files / folder / apps.
I was thinking at achieving the same effect while covering single dock controllers with customized web objects - I vaguely remember, there was a way to put such things on the top of the wallpaper via "active desktop" on XP or win98SE. :?
I'm trying and comparing NeXus and ObjectDock, and I see a lot of potential on NeXus' side to breaking the mould :!:
Users browsing this forum: Google [Bot] and 55 guests
