 Post subject: Nexus tile magnify(?)
PostPosted: Fri Apr 18, 2008 3:15 am
I am having a little bit of a slight issue with Nexus. For some reason, I cannot figure out how to get the tiled backgrounds to magnify in both the horizontal and the vertical directions. I thought there was a way to do this, was I mistaken?
Also, are there more tiles available? Like a cool little tile pack?
PostPosted: Fri Apr 18, 2008 5:09 am
Go to the NeXuS Skinning tab in WorkShelf Preferences and select 'Zoom tiles on magnify effect'.
There's a 1,000 tile pack, but you will have to email me at Winstep support to get it. :wink:
PostPosted: Fri Apr 18, 2008 10:49 am
Am I doing something wrong here? My tiles ain't zooming!
(and my systray needs to be collapsed and expanded in order to refresh)
PostPosted: Fri Apr 18, 2008 12:30 pm
Maybe this will work
PostPosted: Fri Apr 18, 2008 2:05 pm
Ah, that's because you are applying the tile via the Dock Style Editor. That option I told you about is for native NeXuS themes only.
What you can do is make a native NeXuS theme based on that tile. Use the pull up menu on the Themes Manager tab to save a theme with just the NeXuS settings and copy that tile bitmap into the theme folder renaming it to nxtile.bmp.
Users browsing this forum: Apple [Bot], Google [Bot] and 61 guests
