 Post subject: Need just a little help with my Shelf
PostPosted: Sun Mar 09, 2008 9:32 am
Hey so I'm using just the Aero LoRes theme but decided to switch out my shelf for something else, and now the collapsed shelf is sitting just a couple pixels above my start bar and so I was wondering if there is a value somewhere in the theme files that I can edit to lower my shelf so that it matches up with the start bar... Any help would be appreciated...
PostPosted: Sun Mar 09, 2008 2:18 pm
Hi Spixo!
Not sure what you mean by 'switch out my shelf for something else' but what you are describing usually has something to do with the 'reserved screen space', i.e.; the area at the edges of the screen that is never covered up by maximized windows.
If re-starting Winstep Xtreme does not solve the problem, then:
1 - Open the Global Settings tab of NextSTART Preferences. In the Reserved Screen Space section make sure all four edges are set to zero.
2 - If the above doesn't do it either, temporarily disable NextSTART Task Management (Main NextSTART menu -> Settings -> Toggle NS Task Management) to make the Windows startbar visible again. An invisible Windows startbar is still reserving screen space never-the-less, so you might need to re-size it down and then re-enable NextSTART Task Management to solve the problem.
Let me know how it went. :D
PostPosted: Mon Mar 10, 2008 12:53 am
Thanks for your help. It was just that my regular windows start bar was reserving screen space causing my shelf to float 4 or 5 pixels above my visible start var.
Users browsing this forum: Bing [Bot] and 36 guests
