 Post subject: Browser window buttons on Taskbar.
PostPosted: Thu Jul 28, 2005 6:08 pm
I use FireFox. When 2 windows (not tabs) are open, they show up in one Taskbar button (with label 2) instead of the usual 2 Taskbar buttons (using Windows). Is there anyway to get it to show 2 independent Taskbar buttons? Thanks for help.
PostPosted: Fri Jul 29, 2005 2:35 am
My guess is that you turned Task Grouping on, which makes similar windows appear groupped in a single task button (just as it happens under XP).
To disable Task Grouping, open the Tasklist and Systray tab in NextSTART Preferences and, in the Task Grouping section, select 'None' or 'Sort by Similar' instead of 'Group Similar'.
Users browsing this forum: Amazon [Bot] and 73 guests
