 Post subject: Weather module problem
PostPosted: Thu Feb 14, 2008 2:42 am
Module setting does not show any city near mine that would be right. How
can I find the METAR and Weather.com codes I need for Waterloo. Iowa? :?:
Vaughn
PostPosted: Thu Feb 14, 2008 4:03 am
Ooops, sorry, there was a problem in the weather module locations data file that caused most cities from Iowa to be discarded. :oops: It's fixed now, thanks for pointing it out (I have nothing against Iowa, hehe - guess you are the first person in Iowa to use Winstep Xtreme, or at least the only person who bothered reporting the problem :wink: ).
I'll send the corrected METARWCOMDATA.txt file to you by email. :D
PostPosted: Fri Feb 15, 2008 3:52 am
No problem, thank you
Vaughn
Users browsing this forum: No registered users and 38 guests
