 Post subject: disable update notification popup
PostPosted: Sat Apr 18, 2026 12:01 pm
On the update notification pop up window despite selecting Never show the notification, the update notification pop up window keeps popping up and showing up nearly daily. This is a nuisance. How can I permanently disable this notification pop up window?
Thanks.
 Post subject: Re: disable update notification popup
PostPosted: Sat Apr 18, 2026 1:16 pm
Is that the update notification popup or the renewal notification popup?
 Post subject: Re: disable renewal notification popup
PostPosted: Sun Apr 19, 2026 5:17 pm
Sorry, renewal notification pop up.
PostPosted: Sun Apr 19, 2026 5:54 pm
Venkum, I understand how repeated renewal reminders can become frustrating, especially if you're happy with your current version and not planning to upgrade right now.
The reminder you’re seeing is part of how the licensing model works: once the free update period has elapsed, the application will display a renewal reminder when it starts. The “remind me later” option is intentionally limited to the current session, so the reminder cannot be permanently disabled.
That said, this does not affect your ability to use the software - your current version will continue to work exactly as it does now, indefinitely. Renewing is entirely optional and only necessary if you decide you’d like access to newer versions and features.
PostPosted: Sun Apr 19, 2026 7:59 pm
Hmm, but there is an option in the dropdown something like 'Never remind again' or something like that. I selected that and closed the reminder pop up, but the reminder shows anyway next time. So, then what is the purpose of the 'Never remind again' option?
PostPosted: Sun Apr 19, 2026 9:39 pm
Prevents the reminder from showing up again for "this" session, i.e. if your PC is always on and you never rebooted or restarted the Winstep software, you would never see the reminder again.
PostPosted: Sun Apr 19, 2026 9:55 pm
oh ok, got it. thanks.
PostPosted: Mon Apr 20, 2026 1:56 pm
Hi Jorge,
I emailed you a request. Can you please reply? Thank you.
PostPosted: Mon Apr 20, 2026 2:14 pm
Just saw it now. Replied. :D
Users browsing this forum: Amazon [Bot], Apple [Bot] and 93 guests
