 Post subject: eject usb device
PostPosted: Sat Jul 12, 2025 4:32 am
Is it possible (with the latest version of the ultimate version) to create an element in the dock to eject an USB device?
 Post subject: Re: eject usb device
PostPosted: Sat Jul 12, 2025 8:08 am
Try adding an item type Program to the dock with the following in the Filename field
rundll32.exe
and in the Arguments field add the following
shell32.dll,Control_RunDLL hotplug.dll
PostPosted: Sat Jul 12, 2025 6:44 pm
And you can use this icon if you want...
Users browsing this forum: Google [Bot] and 33 guests
