 Post subject: How to disable drag-over flashing effect on dock icons?
PostPosted: Sat Jun 21, 2025 6:10 am
Dragging a file over a dock icon causes it to flash/pulse. Happens even with all launch and hover effects off and happens regardless of theme or icon type. How to turn off this drag-over flashing effect?
Link to the video so You can see it clearly - https://files.fm/f/c8ke79px6c
 Post subject: Re: How to disable drag-over flashing effect on dock icons?
PostPosted: Sat Jun 21, 2025 10:05 am
Thanks for the video.
There is no way to turn that off - it is an important visual clue that
1. The .iCO, .PNG or .TIF image being dragged over the shortcut will replace that shortcut's icon (i.e. that is actually the quickest way to change the icon of a shortcut in the dock).
OR
2. The target shortcut in the dock will be launched with the file being dragged over it as an argument rather than the file being added as a shortcut to the dock (e.g. dropping a .txt file over a shortcut to Notepad will open that .txt file in Notepad)
This "quality of life" feature was added back in 2016 (i.e. nearly 10 years ago) and this is the first time I get a request to turn it off.
Must be that kind of week, as I also just got a request my email to turn off the little "number of running instances" number that appears over a tasklist icon when more than one instance of that application is running (Windows does not provide an actual number for its icons in the taskbar but rather an 'overlapping documents' image, but either way, there must be a visual cue that that icon represents more than one instance of the same application running).
PostPosted: Sat Jun 21, 2025 10:15 am
If the icons are blocked, what other additions can we talk about? (sorry, but you contradict yourself) I would understand you if this indicator (blinking) worked when the icons are not blocked (that is, it would be possible to add an icon).
And also: if you noticed in the video, then this effect is completely broken - if a file from the desktop or from a folder is moved over the dock (but not to the dock, but, for example, to another window), then this effect works and breaks (in different ways), making the icon lighter. It looks terrible...
PostPosted: Sat Jun 21, 2025 5:43 pm
Thanks. Fixed for next release - this would not happen on icons with the magnify effect on, which is why I never caught it.
Your bug report above forced me to have a deeper look at this old code. So, several reasons:
1. Consistency.
2. Not every icon will flash when you drag over it, ONLY those that would accept a document/file as an argument (e.g. executable files OR folders, where the file would be copied or moved to the actual folder, since Winstep application support true drag & drop).
3. The rate/speed of flashing is different if you are dragging an ICO, PNG or TIF file over the shortcut (which would change/customize the image of that shortcut rather than launching the file with the target application), thus allowing you to distinguishing between the two actions.
And since you played the "contradiction" card, now it's my turn lol: if the dock is locked, why drag icons over it? :P
PostPosted: Sat Jun 21, 2025 5:54 pm
Are you serious? And who was talking about icons, and who was even talking about dragging to the dock? :) And what I show in the video - it was just an example so that you understand what I'm talking about... ;)
I repeat once again: if you drag a file to another window (it doesn't matter which one), then in most cases you have to drag it through the dock to get to, for example, the taskbar, and there (at the top of the taskbar), as you can see, the dock is located. Or, as you suggest, make a loop every time so as not to touch the dock? :P
PostPosted: Sat Jun 21, 2025 6:02 pm
AHAHAHA! I just had to laugh imagining users having to do that lol... :D
Anyway, now the "flashing" bug is fixed so it should no longer be a problem in the next release (which is pretty close)...
PostPosted: Sat Jun 21, 2025 6:33 pm
Only because of the presence of this effect of manganese - I had to switch to an older version, where this effect is not present :(
PostPosted: Sun Jun 22, 2025 7:44 am
Considering that was added in v16.2, that's a metric ton of features and new functionality you giving up on just because you don't like that effect.
PostPosted: Sun Jun 22, 2025 8:29 am
I understand, but this effect is so disgusting that I am ready to use the version (15.9.1012) almost 10 years ago. If the update gives the ability to disable (in the settings) this effect - it will be great, if not - well... sorry...
PostPosted: Sun Jun 29, 2025 11:14 am
Nexus Dock v25.6 Changelog.
• An icon could remain in a "flashed" state after dragging a file over it.
I have never seen such a bug in all my time working with Nexus. I dare to believe that this was the fix you talked about in one of your messages above...
If so, then this is not what we were talking about here at all. You either did not understand the subject of our conversation, or simply ignored everything I said... ;) Unfortunately, I do not see any other explanation here. It's a pity...
PostPosted: Sun Jun 29, 2025 2:31 pm
No? That is what was actually happening that "made the icon lighter", in your own words below:
Anyway, moving on...
The "made the icon lighter" above was the real issue that needed fixing. The flashing of the icon, on the other hand, is by design and I explained why in a previous post, as well as why the effect is maintained even when the dock is locked.
Since your dock is locked and you have no need to drag items over it (except when you have to drag through it on your way to the Windows taskbar below or to another window), unless you deliberately linger over the dock the flashing effect - if it even gets to trigger! - will start and finish so fast it will be barely noticeable.
As such, I think this intense dislike for the flashing effect has simply become a "pet peeve" of yours, and nothing would satisfy you other than me adding an option to disable it, which I am not going to do.
I consider every user request (and the proof is that I fixed the bug in the flash effect that left the icon "lighter", despite being swamped with work on the new per-monitor DPI support feature) and am normally more than happy to add requests, but for this I also have to find them genuinely and generally useful, especially if they are going to contribute to what is already a very cluttered UI with yet another option.
This seems something that in the whole universe of Winstep users bothers only 1 person: you. But if you - or someone else - can prove me wrong, I am always open to reconsidering. :D
PostPosted: Fri Sep 12, 2025 9:02 am
If you can't/want to give such an elementary choice, then in that case - there is nothing more to talk about.
Users browsing this forum: Google [Bot], GPT [Bot] and 33 guests
