 Post subject: how to disable application showing dock
PostPosted: Sat Mar 08, 2025 11:31 am
hello,
as title says - I want apps to not force focus dock and showing it if it's hidden. This happens when application that is not focused and some action is made within it, it starts to show dock and the icon for that app starts flashing. I need to click that icon to stop flashing and then it hides automatically again.
 Post subject: Re: how to disable application showing dock
PostPosted: Sat Mar 08, 2025 12:59 pm
Dock Properties -> Behavior tab -> Activation Settings button -> Disable "Activate if hidden when an application in the dock requests attention"
You can prevent the dock from popping up when hidden, but you cannot prevent the icon from flashing as the application itself is requesting attention (unless you don't show running applications in the dock).
This is by design - the Windows taskbar does the same and will also popup if hidden.
PostPosted: Sat Mar 08, 2025 2:27 pm
Good enough for me, thank you!
Users browsing this forum: Apple [Bot] and 20 guests
