 Post subject: ALT+TAB not working properly with Nexus Ultimate?
PostPosted: Sat Dec 28, 2024 1:21 pm
I have Windows 11 24H2 installed.
The ALT+TAB window switcher from Windows is not working properly when Nexus Ultimate is running. Only windows that are not full screen appear in the switcher. I scoured the settings in Nexus Ultimate and could not find anything that fixes this problem. Yet again there are so many settings, maybe I missed something. Or maybe this is only available in Winstep Xtreme?
 Post subject: Re: ALT+TAB not working properly with Nexus Ultimate?
PostPosted: Sat Dec 28, 2024 5:38 pm
There is no such setting anywhere. This has nothing to do with Nexus and everything to do with Win 11 24H2, which is causing this problem - and a heap of others besides. Running Win11 24H2 is just asking for trouble, anyway.
PostPosted: Sat Dec 28, 2024 9:32 pm
AltAppSwitcher is a decent solution that even works on 24H2.
PostPosted: Mon May 12, 2025 9:50 am
I've been testing various setups with Windows 11 24H2 and Nexus Ultimate, and can confirm this ALT+TAB behavior is indeed related to how Windows 11 handles full-screen window rendering in this build, not specifically Nexus itself.
A practical workaround I've found effective is using AltAppSwitcher, as mentioned earlier — it's lightweight, customizable, and doesn't conflict with Nexus.
Alternatively, if anyone prefers native Windows behavior and still wants to stick with Nexus Ultimate, rolling back to Windows 11 23H2 temporarily restores expected ALT+TAB functionality until Microsoft resolves the 24H2 rendering quirks.
Hopefully, Winstep or Microsoft might offer compatibility improvements in upcoming updates.
Let me know if anyone wants a step-by-step on configuring AltAppSwitcher for smoother integration with Nexus.
PostPosted: Mon May 12, 2025 12:39 pm
Oh, look, an AI bot! :D
I'll ban it, but will leave the post itself since the information in it is pretty much accurate.
I think Microsoft have already fixed the ALT+TAB problem, though?
PostPosted: Mon May 12, 2025 3:13 pm
Argh! Exterminate all 'AI' anything - release the Daleks on it. :P Exterminate! Exterminate! :twisted:
Users browsing this forum: Google [Bot] and 33 guests
