 Post subject: System tray
PostPosted: Wed May 29, 2024 5:14 am
Is it possible - insert system tray expand to Sub-Dock ?
 Post subject: Re: System tray
PostPosted: Wed May 29, 2024 11:15 am
It used to be possible - until Microsoft made some core changes to Windows 11 22H2.
PostPosted: Thu May 30, 2024 4:01 am
I'm using Windows 10 [1909], I tried dragging the tray into the sub-dock, but it didn't work, maybe I'm doing something wrong, maybe some other method is needed for this?
PostPosted: Thu May 30, 2024 8:29 pm
Ah, gotcha.
Since you mention sub-docks you are either running Nexus Ultimate (most likely) or Winstep Xtreme.
1. Open the Dock Properties dialog for the main dock. In the Systray section of the Content tab, check 'Show system tray in this dock' THEN 'Always show all system tray icons'. You can now uncheck the 'Show system tray in this dock' setting (I just realized that clearing the 'Show system tray in this dock' setting should not disable the remaining two options).
2. Create a new EMPTY sub-dock in the main dock by right clicking anywhere on the main dock -> Insert New Dock Item -> Sub-Dock
3. Open the newly created sub-dock, right click on it and in the context menu that pops up select 'Insert New Dock Item -> Show System Tray in this dock
This should give you a sub-dock showing all the system tray items in Windows 10.
PostPosted: Fri May 31, 2024 4:18 am
Thanks, it's very simple, but I didn't know how :oops:
Users browsing this forum: No registered users and 75 guests
