 Post subject: AYLLON
PostPosted: Fri May 03, 2024 9:33 am
Hola a todos todo funcionaba bien en mi winstep en Windows 11 pero de repente las voces dejaron de sonar y no entiendo porque alguien me puede ayudar gracias de antemano
 Post subject: Re: AYLLON
PostPosted: Fri May 03, 2024 8:13 pm
This is an *English* language forum, of which you surely must be aware by now. So have the sense if not the courtesy to use an online translation utility! Also, use an appropriate title - in English - for your post, indicative of your problem, not just your name which doesn't tell anybody anything. And *do not* use all capitals. It's offensive. As is posting in a foreign language without an English translation. I sure as hell will not be arsed to use translation myself.
If it were entirely my decision, I would either just ignore your post as it is or even delete it. As it is, you may be in luck as 'Mr. Winstep' Jorge Coelho is a bit of a linguist and speaks Spanish.
PostPosted: Fri May 03, 2024 8:33 pm
¿Puedes publicar una captura de pantalla de la pestaña "Sonidos" en Preferencias?
¿Son sólo las voces o también los otros sonidos?
Users browsing this forum: Bing [Bot] and 31 guests
