 Post subject: System tray icons not showing
PostPosted: Tue Apr 23, 2024 11:55 am
Hi guys!
I usually see a lot of icons in system tray - but not on Windows 11. I usually use it for disconnecting usbs, clicking on live teamviewer etc.
If I turn off Winstep Extreme my icons are showing in Windows. I don't use next start so I can't access them that way.
bookie56
 Post subject: Re: System tray icons not showing
PostPosted: Tue Apr 23, 2024 11:23 pm
bookie56 wrote:
Hi guys!
bookie56
This topic has been covered to exhaustion. Try a forum search for 'System tray Windows 11' or some variation. :)
PostPosted: Wed Apr 24, 2024 5:20 pm
bookie56 wrote:
Hi guys!
bookie56
Yes..I have seen since posting...
Obviously a sore point with many..I am not going to add to that Windows 11 is a pile of crap and so is Microsoft..
Hopefully a solution will be available at some point.
bookie56
PostPosted: Thu Apr 25, 2024 5:47 am
bookie56 wrote:
bookie56 wrote:
Hi guys!
bookie56
bookie56
More and more people seem to come to the conclusion that Win 11 is the biggest pile of shite yet, and a lot are coming over to Linux - plenty of them showing up in Linux-related forums etc. now! :) For as long as I still have to use the odd Windows session I'm sticking with Win 10, my main OS has been Linux for a long while. :D
Alas, other than the current workaround I doubt a full solution to the systray issue can be found because of the programming language of Winstep. :(
PostPosted: Fri Apr 26, 2024 10:59 am
Hi again...
A nice solution for eject usb would be nice for now...I have tried creating a desktop shortcut and dragging it to the dock but the eject has two stages instead of the one in Microsoft...
bookie56
PostPosted: Sat Apr 27, 2024 1:56 am
bookie56 wrote:
Hi again...
bookie56
Yeah, that sounds like a good idea! Don't know if it would be possible, but sounds like it might perhaps be doable as an internal command perhaps....
Of course, the simple alternative would be to go back to Win 10... :)
PostPosted: Mon Apr 29, 2024 4:43 pm
Just make sure that the "Always show all system tray icons" setting in the Winstep application is OFF (in NextSTART: Preferences -> Taskbar tab -> System Tray Settings button -> System Tray Settings section of the dialog). This way that particular icon should appear in the systray overflow area which you can open by clicking on the little blue arrow symbol.
You still won't be able to see the SYSTEM systray icons (Network, Volume, etc) but if you click on the white cog you will be able to access the Windows pop up panel that combines all these functions.
Users browsing this forum: Bing [Bot] and 31 guests
