 Post subject: Is there a way to add the "libraries" icon
PostPosted: Wed Mar 06, 2024 8:57 am
Hello,
I'm enjoying the software. Is there a way to add the "libraries" icon (the one with music, documents, pictures, etc) to the dock?
:Moderator's note - Spam removed! :/moderator's note: - nexter
 Post subject: Re: Is there a way to add the "libraries" icon
PostPosted: Wed Mar 06, 2024 1:48 pm
Open windows explorer, left click and drag the main Libraries icon onto the dock (if you can find it, I don't use libraries here under Windows 11 and since I use compact view I never see that icon either)
