 Post subject: Display Ultimate on second monitor?
PostPosted: Mon Jan 01, 2024 8:25 pm
Hi,
I'm extending my display onto a second monitor (in Win 11).
My main Nexus taskbar is docked to the bottom of the screen on my primary monitor. I have the Windows taskbar toggled off.
Is there some way I can get my main Nexus taskbar to display on both my primary and secondary monitors?
TIA
Jeff411
 Post subject: Re: Display Ultimate on second monitor?
PostPosted: Tue Jan 02, 2024 5:50 am
Not really in the sense you probably mean. You will have to create a second dock (right click on your main dock's Nexus Control icon, open the Dock and Shelf Management menu, then click on Duplicate dock) and use that one on your secondary monitor.
The only problem with this is that from then on you will have to manually duplicate any changes made to the primary dock on the secondary dock. But it works.
PostPosted: Tue Jan 02, 2024 1:04 pm
Thanks Jorge,
I'll do that.
Users browsing this forum: Amazon [Bot], Apple [Bot], Majestic-12 [Bot] and 51 guests
