 Post subject: Open a subfolder with a mouse click
PostPosted: Sun Nov 19, 2023 4:31 pm
Hello community,
when I put a folder in the dock and I select the option "open the folder as a menu" then I can see the subfolders. If I want to open such a subfolder, I can only do so using the context menu. It doesn't work with a double click or a single click. Is there a setting to open a subfolder with a mouse click on the folder?
Best regards
 Post subject: Re: Open a subfolder with a mouse click
PostPosted: Mon Nov 20, 2023 12:58 pm
You mean open the sub-folder in an Explorer window? Double clicking the folder name in the menu should do it, I just tried it here and it worked as intended.
Might have something to do with how fast (or slow) you double-click? Try triple-clicking instead, but very fast.
PostPosted: Mon Nov 20, 2023 1:03 pm
You're right. I was too slow...
Best regards
Users browsing this forum: No registered users and 29 guests
