 Post subject: Nexus icons completely not showing
PostPosted: Sun Aug 13, 2023 8:14 am
I just installed nexus and all the icons I see are question marks. I dont know why this is happening and i am a complete beginner to nexus so if i am doing something wrong, correct me. Please Help me with this.
I have windows 10 Pro , 12 Gb of ram , AMD fx-6300 processor if it helps in any way.
File comment: Like this:
 Post subject: Re: Nexus icons completely not showing
PostPosted: Sun Aug 13, 2023 3:29 pm
Details, details, details! Please, do go and study - and follow! - the Board Rules and Guidelines, and get to know the forum in which you want to post a little, before posting. Personally, I don't like to have to ask supplementary questions, so I don't. So, please heed my advice.
PostPosted: Sun Aug 13, 2023 5:43 pm
Well, what I see in that screenshot is definitely not the default configuration of Nexus, nor is it even the default theme. The question would more likely be "what have you done to it" and, as Nexter explained, details are extremely important.
What happens if you press CTRL+F11 to bring up Preferences, navigate to the Advanced tab, click the Troubleshooting Options button, then the Backup button to save current settings (you can later restore in Preferences -> Advanced tab -> Restore button), and finally the 'Reset Everything' button? Do you get the default dock back?
