 Post subject: Windows 11 latest updates and NextStart
PostPosted: Sun May 28, 2023 6:17 am
Hi there,
Made a couple of updates yesterday (KB 5026515 and 5026446) and since then I got a problem using NextStart... I've been always using it along with Start11 to display a Windows7-Start Menù style, but after the updates, if I launch NextStart, the Start Menù is display in Windows10 style and Start11 can't do any change to it. If I quit NextStart, I got the Windows7 style back.
Is there something I can do to get the 2 softwares back to work as usual?
I'm also using ExplorerPatch to keep the Windows Taskbar in top position with autohide on, but this seems not to affect the problem in anyway.
Thanks for your help!
Baio
 Post subject: Re: Windows 11 latest updates and NextStart
PostPosted: Mon May 29, 2023 12:19 am
Baio73 wrote:
Hi there,
Baio
No idea whatsoever, I'm afraid, as I'm permanently sticking with Win 10, sorry. So, over to you, Jorge, if you're not too busy. :)
PostPosted: Mon May 29, 2023 1:51 pm
Thanks for your replay, I'be glad to give Jorge all the infos he needs.
Just let me know!
Baio
PostPosted: Wed May 31, 2023 7:11 am
Similar issue just using Nexus Ultimate and Start11 works when nexus is unloaded and not when loaded so looks like a docklet issue.
Fink
PostPosted: Fri Jun 02, 2023 12:59 am
Fink
More likely a Windows 11 issue perhaps.
BTW, there's no such thing as a 'docklet' - Nexus is a dock. :)
Users browsing this forum: Bing [Bot] and 31 guests
